57 Floor pan
Old Sep 21, 2006 | 02:32 AM
mkrog's Avatar
mkrog
57 Floor pan
I just recieved the floor pan I ordered from L.M.C. and it is differant from the stock floor.No mounting hole for the cab mount and no hump that goes from the center tunnel towards the outside and ends by the mounting bolt hole.Is this what to expect for replacement floor pan?has any one used this pan on a 57 -60 F 100?
Old Sep 21, 2006 | 05:53 PM
black58's Avatar
black58
I hate when that happens. You don't even know if you've got the right part. Does it appear to fit? Does it have the cut out for the step inside the door? I guess if you had to you could cut the hole for the cab mount into it. But that still sucks. I was able to get a used fire door from a demolition site for free and I cut it up and used it for my floorpans. Actually I used it for my front rollpan and a few patch panels too. I hope you find the info that you need. John
Old Sep 22, 2006 | 12:10 AM
mkrog's Avatar
mkrog
[QUOTE=black58]I hate when that happens. You don't even know if you've got the right part. Does it appear to fit? Does it have the cut out for the step inside the door? I guess if you had to you could cut the hole for the cab mount into it. But that still sucks.
Yes it has the cut out for the step.Ican drill a hole for the cab mount but it is countersunk and it's large ,over 1and1/2 in across.Cant figure out how to countersink it.
