specs on granny 4spd
[font size="1" color="#FF0000"]LAST EDITED ON 04-Apr-01 AT 08:28 PM (EST)[/font][p]have 65 ford f100 would like to convert granny 4 speed to toploader. 352FE engine, can anyone point me to the specs of my tranny. will toploader bolt to current bellhousing? main concern is highway driveablity. truck is going from work to street truck.
I'm not sure if you'll be able to bolt the toploader right up but the highway drivability will not change both trannys have a 1:1 ratio in 4th. If you want to lower your RPM range you need to go to a higher rear end gear ratio. You probably have 389:1 gears now 323:1 will give you better highway mileage and speed. I hope this helps.
