how to build
Old Sep 20, 2006 | 08:08 PM
GOTH_TRUCKER's Avatar
GOTH_TRUCKER
Smile how to build
hey ya'll i just got a 300 l-6 that i want to build to the hilt u know? so manely wut is the best things to do to make the most powerfull 300 l-6 im talking lots of hourse power and torque something that will make the rubber roast off the tires like nothing. so guys here is where ur emagination comes in,cause there is NO budget on this build,thx ya'll
Old Sep 21, 2006 | 02:17 AM
j41385a's Avatar
j41385a
Get a Big Cam, Port and polish the head, Get Ross High compression forged pistons, Get good ignition, Get a 4V or an 8V intake and whichever carb(s) work(s) best, Get a header, and there you go. There are some other things like Small block chevy valves, because they are bigger. But anything you can imagine doing to an 8 banger for more power works for a straight 6.
Old Sep 21, 2006 | 11:51 AM
SR_Crewchief's Avatar
SR_Crewchief
Originally Posted by GOTH_TRUCKER
NO budget
So this is a fantasy build.
Find a forged steel crank. Balance it.
Forged rods.
Custom HIGH compression pistons.
Wait for the Classic Inlines aluminium head and custom valves to be available and get them.
Schreider roller cam.
Probably would be a good idea to oring the block.
Wait for Mugnuson blower kit to be available. Currently in developement for SB6 for Classic Inlines. May not be produced for the BB6 though.
Probably will need a custom girdle for the mains.
Upgrade all fasteners!!!!
Decide if you want carb or fuel injection. Both when setup right will feed this beast.
This kind of combination probably won't be streetable. Nor is the rest of the drivetrain addressed. If done right you'll have a tire roasting engine that will run up to 7k! It is dependent on products that are "in developement" and won't be cheap.
Old Sep 21, 2006 | 06:16 PM
Col Flashman's Avatar
Col Flashman
Go to my "Gallery" to view the Specs for what I've done to mine to achieve 400FPT @ 3200RPM & 300HP @ 4600rpm.
Though you'll probably wish to to do some things a tick differently, such as & different Cam, as I went for the mild Milling Torque cam.
Old Sep 22, 2006 | 02:53 PM
GOTH_TRUCKER
this is no dream build i have no budget cause this is goin to be a shop truck that we are building,my shop has got extreme buiseness lately so we have a huge surplus,so guys thanks and keep um' coming
Old Sep 22, 2006 | 03:08 PM
SR_Crewchief
AH!! You mean that you have an "unlimited" budget!!
Seriously, that's what I thought you ment.
Your first question to answer is...what is the actual intent? Racing? Towing? OR trails? Crawling? Pulling? ??? Once that's known, then you can target the build.
Next, Who's doing the build? You? your shop? ???
Who's available in your area that does performance builds? Do they handle big block sixes?
Old Sep 22, 2006 | 03:27 PM
Silver Streak's Avatar
Silver Streak
You need to answer the question above before you decide anything else about the build. Different applications need different engine building tactics.
Old Sep 23, 2006 | 09:23 AM
GOTH_TRUCKER
ok,it will tow,thats for sure,but i also want something for the trails,so low end torque qwould be good. i am doin the build
Old Sep 23, 2006 | 11:40 AM
nevrenufhp's Avatar
nevrenufhp
low end torque is what the 300 is all about!
I say turbo/ supercharger is a must for this kind of power.
bismic
Mar 9, 2022 09:20 AM
Nudnik
Nov 13, 2013 09:34 AM
iforeman
19
Jul 24, 2010 11:10 PM
rockher_man
17
Aug 7, 2009 10:11 PM
