Pinion rattle (steering)
Old Sep 20, 2006 | 08:01 PM
BKranger's Avatar
BKranger
I've had a rattle in the front end of my truck for some time, and I finally figured out it is coming from the point where the steering shaft bolts to the steering rack. I pulled the shaft out of the truck, and I can grab the part that sticks up out of the rack (to which the shaft bolts - I assume this is the back end of the pinion) and shake it back and forth. Its not really excessive or anything, but it certainly isnt tight. Does anyone know how much play is normal here (if any at all), and if I should be worried about it? There are no leaks in the power steering system as of yet - this rattle has been going on at least 4-5 months. The truck is a 2000 ranger, 2WD flareside (or whatever they are calling it nowadays), 4.0 OHC, with 75k miles on it.
Thanks!
BK
Old Sep 21, 2006 | 12:54 AM
monsterbaby's Avatar
monsterbaby
Welcome to FTE BK,
Lets bump this back up to the top and see if someone has that spec for you. I don't happen to know.
