Engine compartment cleaning
Old Sep 19, 2006 | 08:10 PM
EPDP99's Avatar
EPDP99
whats the best way to do it. Just did a hard pull and had an episode of puking. whats the best way to clean it without any electrical issues?
Old Sep 19, 2006 | 08:20 PM
raptor131's Avatar
raptor131
i have used the store brand engine cleaner, not degreaser i think it's called "engine brite". followed the owners manual and label instructions and no ill effects. but a clean engine compartment. the reason i clarify the type is i actually bought the degreaser and it is too harsh on plastics and rubber
Old Sep 19, 2006 | 09:35 PM
tvsjr's Avatar
tvsjr
Eh. No cleaner required. Coolant is extremely water soluable... I used two gallon pitchers of water and a rag to clean off my last puking episode.
Old Sep 21, 2006 | 09:11 PM
ffemtp's Avatar
ffemtp
You mentioned puking... my PSD puked and the dealer said it was the Head Gasket had blown. How can one tell if the truck puked or it is a blown head gasket? The only signs of antifreze were immediately around the radiator cap/hose connecting reservoir to DS radiator.
Old Sep 21, 2006 | 09:54 PM
6L PWR's Avatar
6L PWR
If your Head Gaskets were blown you'd probably start seeing some signs of water/Anti-Freeze in your oil and if you get the boost up high you'd probably hear it leaking from the pressure. I'd be willing to bet that yours just puked a bit. I'm pretty heavily modded and still running the stock head bolts and gaskets and have only had some puking issues.
