Tech question on 6.0l
Old Sep 19, 2006 | 07:35 PM
mjlevi's Avatar
mjlevi
say perhaps I had a faulty injector, or in other words an injector that is not working...would I know that such is not working by the performance of the engine alone? would I be able to feel such an obvious problem? or is there any credit to having such a test performed to verify that all injectors are working properly? I do not have any such problems at this time,.. but it was once mentioned to me that I can actually lose an injector and not even know it on this particular diesel engine... and/or would such a problem set a trouble code as well? and be as technical as you can, thanks!!
Old Sep 20, 2006 | 04:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...bump.....
Old Sep 20, 2006 | 09:10 AM
Vic_Ferrari's Avatar
Vic_Ferrari
Usually, you would feel a roughness or decrease in performance, but sometimes it's not as noticeable if the injector hasn't completely failed.
It's as simple as pluggin in an NGS 2K and checking the injectors function, so if you're worried about it, most competent diesel shops can do this.
Old Sep 20, 2006 | 05:12 PM
CanadaGuy's Avatar
CanadaGuy
I'd agree with whoever said that you might have a bad injector and couldn't notice it if it were a 7.3, but a 6.0 will run noticably rough and sometimes fall flat on it's face if it had a bad injector, especially when it's cold. Don't expect the CEL to come on though,
