anyone who can help
also, someone told me in ny ( you might not be from here, but whatever ) cats are warrantied for 8 years? which i guess would mean Ford would have to give them one for free to put on my truck....no?
thanks in advance everyone
nick
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
nick
Since you bought your truck "pre-owned" and don't have a reliable history, it would be in your best interest to do some basic maintenance. Check the air filter, change the fuel filter, MAF sensor...that sort of thing. Also, without question, an oil and filter change. I would recommend pulling one of the spark plugs to see how it looks. Then take a second feel at how she is running.
Going up a hill: if you leave the throttle at a steady spot, it WILL lag up that hill. Throttle position is what determines how a system will react by giving more fuel and the tranny will respond accordingly to the speed change. By climbing, you are now trying to move 3 tons of weight up a hill instead of across a flat run of asphalt. It will need more juice to get that done. Give it more gas and it will climb.
I am in New York too. Give me a holler anytime. Good Luck!
If you don't know the exact history of the vehicle, down to every service, do the following, as far as money and time allows:
Change the fuel filter.
Do the spark plug maintenance. This means remove, clean (or replace), anti-sieze, reinstall, and use dialelectric grease. Replace the COP boots if they are dry rotted or even just "funky"
Clean the MAF.
The "shakes a bit" sounds like you have a low-RPM/high-load miss. That could be a COP. Do the above, and see if it still shakes at that point. If it does, get the misfire counters read, and if there is a specific cylinder misfiring, it might be time for a new COP.
Report back!
