looking for basic info on my '03 explorer.
Old Sep 19, 2006 | 04:52 PM
eddie21's Avatar
eddie21
I'm looking for some basic info on my 2003 explorer. Stuff like what to watch for, known problem's and any tips anyone might have.
My Explorer is an eddie bauer with the 4.6ltr sohc, 5-spd automatic o/d tranny, also has the tow pkg with a 3.55 rear axle.
I would also like some info on the tranny( type, etc.) and the 3.55 rear end.
Thanks in advance.
Chris
Old Sep 19, 2006 | 08:59 PM
ptm526's Avatar
ptm526
I have a 2002 EB with the 4.6 V8 and 3.73 REnd. The biggest problem I had was a howling rear end between 45 - 60 mph. Ford finally replaced the entire differential assembly at 36,000. That fixed the noise. Also replaced shifters in transmission because it would shudder when it shifted. Just replaced the DPFE sensor last week when I was getting a P0401 reading. SO far so good. Now the only thing that irritates me is the engine that sounds like a diesel. Ford says it is normal. Now have 53,000 miles so guess I will put up with that for awhile. Like the V8 with exception of the noise. Don't hear it after torque converter lock up.
Old Sep 20, 2006 | 11:58 AM
Steina's Avatar
Steina
CO River Rat
Chris -
If you've got the tow package on that '03 you have a 3.73 LS rear end, not a 3.55; as PTM526 mentioned, there have been problems with noisy clutch packs in the LS rear ends. You might want to check with your service manager to see if your '03 needed the tranny additive, and if so whether it was put in.
Steve
Old Sep 20, 2006 | 05:45 PM
eddie21's Avatar
eddie21
Originally Posted by Steina
Chris -
Steve
Steve, thanks for the info. I was going by my window sticker that I kept when I bought the truck new. It does have a ford factory hich but it looks like the lighter duty one. The window sticker states under options a 3.55 rear axle, hmmm now I'm confused.
Old Sep 20, 2006 | 06:40 PM
Steina's Avatar
Steina
CO River Rat
They all have a receiver hitch, but if it doesn't have the tow package then that '03 has a Class II 1-1/4" receiver and a 4-pin electrical connector with 3.55 rear gears.
Steve
Old Sep 20, 2006 | 07:00 PM
eddie21's Avatar
eddie21
steve, you got it. thanks for clearing that up. i assumed since it had a hitch it had a tow package, didn't know they all came with a standard hitch. I stand corrected on the tow package statement.
Chris
Old Sep 21, 2006 | 06:34 PM
Drew'Z's Avatar
Drew'Z
Not to hijack but i just bought a 03 xlt v6 would i have the same rear end problems because i can hear a howling noise above 60 mph
Old Sep 21, 2006 | 06:51 PM
Steina's Avatar
Steina
CO River Rat
Drew -
Depends - do you have the 3.73 LS or 3.55 rear gears?
Welcome to FTE!
Steve
Old Sep 25, 2006 | 11:56 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Ford now installs a new clutch pack in the differential, rather than replacing the entire assembly.
And the transmission thing they did was replace the solenoid. The Mercon-V was causing a brass washer to swell making the solenoid stick and not wanting to allow for shifting. They have since reformulated their transmission fluid so this won't happen. (and introduced an additive you can put in the old formula to prevent this)
Old Sep 27, 2006 | 07:33 AM
Drew'Z's Avatar
Drew'Z
I have the tow package Class 3 reciever. But how could i check what gear i have?
Old Sep 27, 2006 | 07:42 AM
ptm526's Avatar
ptm526
As far as I know, the class 3 hitch only comes with the tow package which includes the 3.73 LS rear end.
Old Sep 27, 2006 | 07:46 AM
Drew'Z's Avatar
Drew'Z
ok thanks.....
Old Sep 27, 2006 | 11:37 AM
njf207's Avatar
njf207
What rear end did the 02' with the tow package come with.
Old Sep 29, 2006 | 05:25 PM
Steina's Avatar
Steina
CO River Rat
njf207 -
The same - 3.73 LS
Steve
anthonym92
17
Oct 28, 2016 04:08 PM
pappy19
1978 - 1996 Big Bronco
Feb 23, 2016 08:17 AM
cnvF250
2009 - 2014 F150
Feb 3, 2012 05:58 PM
XolieX
Feb 25, 2005 04:38 PM
lgspitler
Jan 3, 2003 07:08 PM
