I have a 2007 F350 CC and I am wanting to put a sub behind the rear seat. I am looking at a 12" Pioneer Shallow mount sub that wants 350 W RMS, so I am going to need a pretty good size amp. I was just curious where people are installing the amps for their subs. I am thinking about putting it under the drivers seat, but it's going to be a close fit with the bracket to move the seat forward and back. Thanks in advance for the help!
For the main HU amp I cut a board to fit the amp and the rear wall, (behind the larger drivers seat) as far as I could to the door, carpeted the top side too.
Then I used a high grade silicon to stick it to the rear wall after cleaning the rear wall to the metal & screwing in the amp to the wood. The sub amp was mounted on the floor below this unit to drive the sub.
It has been a year and all is well. I used a 10' kicker stock box for my sub.
