Rear End Recommendations
Old Apr 23, 2001 | 03:37 PM
62stepside's Avatar
62stepside
I have a '62 with a 223 and the original LD 3spd. The rearend is the orignal 3.73 (I think, perhaps a little higher). I want to here some recomendations on a lower ratio so that I can run highway speeds (70-75ish) without being almost at wot. Or, how hard would it be to add an overdrive unit to my existing tranny? Perhaps a later Ford tranny w/overdrive will bolt up to my block?
Tyson
'62 F100 stepside 223 I6 (starting a frame-up)
'71 F100 longbed 360 V8 (recently sold)
'89 Ranger (daily driver)
Old Apr 23, 2001 | 05:55 PM
jowilker's Avatar
jowilker
Tyson, 3.50 is probably about as low as you should go with that engine to keep it balanced economy & pull. If take off doesn't matter 3.25 will get you good mpg but it will be weak.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Apr 23, 2001 | 08:47 PM
sixte1f100's Avatar
sixte1f100
Tyson I'm putting in 3.25's this saturday. I have a 223 with a 4spd. I should be able to tell you late saturday or sunday how it goes.
Sixte1f100
Old Apr 23, 2001 | 11:00 PM
truckfarmer's Avatar
truckfarmer
A friend of mine installed a late model T-5 5 speed transmission behind his Y-block and another friend's 223 also. Go to the links, click on Badgerland F100's, scroll down to the "Ask MR" tech section. MR is the guy to ask how.
Old Apr 25, 2001 | 08:20 AM
truckfarmer
Old Apr 25, 2001 | 08:46 PM
caseman's Avatar
caseman
I had a 3 to 1 laying around and put it in my '62 with a 223. No gain on the top end, and no power against a 30 mph Kansas headwind. Stay with a 3.25 or 3.5.
