98 lifters
Old Sep 19, 2006 | 07:35 AM
ripcurl94's Avatar
ripcurl94
98 lifters
my 98 xlt with 109k(pushrod) seems to have lifter noise if i am going 70 mph and i try to accelerate.. is this common..?
Old Sep 19, 2006 | 10:12 AM
aquanaut20's Avatar
aquanaut20
sounds more like PING, time to clean all the sensors in the intake as well as the throttle body.
Old Sep 19, 2006 | 10:29 AM
ripcurl94's Avatar
ripcurl94
Pinging.. yeah .. i could say it pings.. but i have cleaned the throttle body.. what do recommend i clean the sensors with?? which sensors .. thanks
Old Sep 19, 2006 | 10:42 AM
aquanaut20's Avatar
aquanaut20
When your engine is cool, remove the wiring clip from the side of the black plastic sensor part of the MAF aluminum body(near the air cleaner box). To remove the MAF interior sensor wire, you will need a Security Star (Size T15 or T20) screwdriver or screwdriver bit for a power screwdriver. Remove the security star-head screws and carefully remove the sensor. You will see the two sensor filaments…they look almost like the filaments on a light bulb. Carefully spray the filaments with an O2 safe carburetor cleaner, such as Gumout. Let it dry thoroughly. I help mine along with a careful blast or two of canned dry air. While it is drying carefully wipe the aluminum mount surface of the MAF body if there is any dust there, but be careful not to get dust in the mount hole. When the sensor is dry, replace the sensor back in the MAF body and secure with the security star-head screws. These don't need to be torqued down, just simply hand tight. Replace the wiring clip. Then start up your engine.
