posi rear end
Old Sep 18, 2006 | 09:47 PM
oscar_007's Avatar
oscar_007
posi rear end
I like to do burn outs on my 69' F250 camper special with a 390 because it has plenty of power to do them. The only problem is that most of the time, I only have one wheel spinning. Sometimes, if I am lucky, I will get 2 spinning.
What do I need for the rear end for both to spin. I have heard of Posi and Limited Slip, but is there some kind of "add on part" that I can put in my current rear end.
Thanks
Old Sep 18, 2006 | 10:05 PM
beedevil1973's Avatar
beedevil1973
go to richmond gears .com. they have some cool videos there that will answer your question about that
Old Sep 20, 2006 | 12:03 PM
Mil1ion's Avatar
Mil1ion
Posi-Traction is a GM term.
Ford is Limited Slip or Traction-Loc
You can just swap the diff (If axle splines are the same) or the whole axle housing.
Look for a truck an B or C (number) ...code axle on the door plate for a Dana axle.
Old Sep 22, 2006 | 05:39 PM
jwtimme's Avatar
jwtimme
you can buy a posi lock for any rearend that you want ans do not need to replace housing or axils but it would be recomended to replace bearings and other parts at the same time.
Old Sep 23, 2006 | 09:16 PM
FordBoypete's Avatar
FordBoypete
A carrier assembly equipped with a set of 4 pinion (spider gears) acts like a FoMoCo or other type traction lok/ limited Slip/ Detroit locker.
If you back up straight on it, then drive straight ahead to a launch point, it will lock both wheels until you turn, swerve, brake, or otherwise deviate from going straight ahead. I can shred a set of tires with my 460 & a 4 pinion carrier, 9", set up. Although I must admit it's rather pointless.
But the set up also gets me great launches in the 1/4 mile and if I "breath" the loud pedal right I don't smoke any tires at all, and can cut a 12.60 every time. . . . .
FBp
Old Sep 23, 2006 | 09:36 PM
70SWGR's Avatar
70SWGR
I'm new here but alot of us mopar guys have DoctorDiff(Cass Eslick in Polson,MT) build the dana's and 8 3/4's for our cars,he does excellent work and his prices are hard to beat.
Here's his website http://members.aol.com/doctordiff
On your truck you could swap in a power-lock,track-lock or detroit locker in the dana,I would choose the power-lock.
V8Ranger302
1983 - 2012 Ranger & B-Series
Sep 22, 2010 10:57 AM
Fat&Bald
15
Sep 12, 2008 04:12 PM
gearhead351
May 19, 2006 11:37 AM
Native Gearhead
Sep 23, 2003 12:38 PM
Dusty McGuire
Aug 5, 1999 07:52 PM
