AFE and MBRP
Old Sep 18, 2006 | 08:59 PM
f250meangreen's Avatar
f250meangreen
AFE and MBRP
What are the differences between these two? Do they both bolt directly to the cat?
Old Sep 19, 2006 | 10:21 AM
DiscountPowerPrt's Avatar
DiscountPowerPrt
Both companies make cat back exhaust sytems. Is that what you are refering too?
Old Sep 19, 2006 | 01:00 PM
f250meangreen
I will do a Turbo back and I know the MBRP will bolt directly to the cat. Does the AFE do the same or will modification be needed?
Old Sep 19, 2006 | 01:11 PM
DiscountPowerPrt
The cat delete from both companies work the same. They directly replace the factory cat, both ends are identical. The only other differance I can think of is that the AFE tail pipe is 2 piece and the MBRP is 1 piece.
