Possible wiring problem?
Old Sep 18, 2006 | 07:35 PM
Chuck88's Avatar
Chuck88
OK yesterday i decided to finally drop my rear tank and fix the ground wire so my gauge would work again. got it all back up and the gauge worked, then stopped working, i put some terminal grease all along the top of the connector and now it stays at empty instead of full. another thing i hit the switch to see if my front tank was working(used to not) after moving around the wires in the rear and it does! only thing is i think it clogged up the filter cause now either tank will not work. I hate to ramble on but the noise of the rear pump also changed, used to be loud now is very quiet. any comments would help.
Old Sep 21, 2006 | 07:38 PM
Chuck88's Avatar
Chuck88
update
okay i got the rear tank working again. the reason it sounded different is becasue now both pumps are kicking on when the switch is on rear and neither work when on front. now all the fuel from the rear will go to the front and overflow it. anyone have an answer?
