Sponsored by: Kumho
wheel problem?? need your help!!
Old Sep 18, 2006 | 03:41 PM
fitmonkey1219's Avatar
fitmonkey1219
few days ago my driver side front wheel sounded like it was loose. everytime i hit a bump it rattles really bad. so i took it to a buddies house and we tightened the lug nuts thinking that was it...it wasn't. it's still making the sound. it sounds like having lug nuts completely off a rotor and it just bouncing around in side a hupcap (best way to describe the sound)...and this happens over every lil crack/bump in the road...please help!!
2000 f150
Old Sep 19, 2006 | 07:28 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Sounds to me like you are either missing brake pad clips, you have a loose caliper, or a loose shock mounting bolt.
Start looking at stuff connected to the a-arms and knuckles. They move when the tire does.
Cody
Old Sep 19, 2006 | 08:31 AM
merlynr's Avatar
merlynr
Drive over rough road where it normally rattles, but with slight pressure on the brake pedal and see if rattle goes away. If so, then it is brake pads or calipers.
Old Sep 19, 2006 | 04:07 PM
fitmonkey1219
thanks guys...i will do this...i was on a other forum and they said it could be a ball joint or wheel bearing...opinions?
Old Sep 19, 2006 | 04:41 PM
seventyseven250's Avatar
seventyseven250
It's very easy to check the shock mounting. Just see if you can wiggle them with your hands.
I've had a loose shock, and it made exactly the sounds you describe.
Old Sep 21, 2006 | 12:28 AM
fitmonkey1219
you guys were right...
took the tire off and looked at everything...come to find out it was the brake caliper bracket...the two bolts that hold it on, i could literally finger tighten them on..not good haha...but we tighten them down...now everythings fine...
thanks again for the help guys!!
