How much are they worth?
Old Sep 18, 2006 | 11:35 AM
david00f150's Avatar
david00f150
I need some prices on about how much these parts are worth:
1.) Freshley built 302 with 204/214 cam, reworked E7TE heads, edlebrock performer upper and lower intake manifolds, hooker long tubes, all new bearings, freeze plugs, accessories, new pistons, ARP rod bolts, motor bored .30 over with reconditioned rods, motor balanced and crank turned by creditable machine shop. All assebled and motor ran for about 3-4 min. max.
2.) dana 40 limited slip rear end with 3.73 gears
3.) C6 tranny w/ transfer case
Old Sep 18, 2006 | 12:09 PM
Kemicalburns's Avatar
Kemicalburns
well the motor maybe in the 1000-1500 range but that cam may not work well in a 4wd.
not sure what a DANA 40 is
c6/tranny depending on condition about $1000 if working
Old Sep 19, 2006 | 10:49 AM
david00f150
Well the cam should work well because the power range is from idle to 5000 rpm
