Lariat Fender Flares
Old Sep 18, 2006 | 09:23 AM
97_Ex's Avatar
97_Ex
I have a 2006 F150 Screw that is white/tan. I have never really liked the way the fender flares are painted tan... my question is can you removing them or will it be better to paint them? Thanks
Old Sep 18, 2006 | 01:38 PM
yellow98cobra's Avatar
yellow98cobra
Swap them out for a set of bushwakers
Old Sep 18, 2006 | 01:46 PM
edillen's Avatar
edillen
You should be able to pull them off and it will look like an XLT.
Old Sep 18, 2006 | 01:54 PM
is300wrx's Avatar
is300wrx
i believe you will be left with holes on the side of your truck is you do. There would be holes used by the flares to guide itself in. I may be wrong but that is how it is with the FX4s....
Old Sep 18, 2006 | 06:33 PM
triple8's Avatar
triple8
The dealertold me there are actually clips that are welded to the steel under those ugly flares, not just holes. I asked the day I picked up my Lariat because I was going to remove them. I too hated the tan paint, they should be body color. You can get them painted, but either do it on the truck or plan on them breaking at least one trying to remove to paint. They are $100+ea. if I remember correct.
Old Sep 21, 2006 | 05:51 AM
scottsdalelariat's Avatar
scottsdalelariat
I have removed my Lariat's flares and it isn't pretty!!
My '06 Lariat has body colored flares, so I took them off to prep the lower half of the truck to a new color, sapphire blue metallic while the hood and upper cab remains in the stock Smokestone Metallic.
Each flare has about 8 or 10 holes behind them in the sheet metal of both front & rear fenders with plastic clips that hold the flare in tight, no glue or chaulk or double sided tape is used, just these white plastic clips that are attached to the plastic fender flare.
The stock flares are very soft plastic and I was told by my dealer's body shop that once factory painted, it's hard to make them look nice when repainted - so he told me to order a new set without any paint to have a perfect match to my new exterior blue color. Instead, I'm going to fill all the holes with new welds in the sheet metal and leave the flares off when I get the lower half painted for a much nicer, smoother look to the fenders.
Hope this helps your decision.
Old Sep 27, 2006 | 10:54 AM
triple8's Avatar
triple8
If you have a solid colored truck they will be body color, only the two tones from the factory got accent colored.
mikespecht
6.7L Power Stroke Diesel
Mar 13, 2020 07:07 PM
hoss66
Jun 13, 2015 05:54 PM
rdwebb
Aftermarket Products
Nov 10, 2013 11:13 AM
88idigray
Oct 22, 2013 12:52 PM
clintusaf
Aug 17, 2013 11:34 PM
