CCV Mod Modification
Old Sep 18, 2006 | 07:04 AM
Uzumati's Avatar
Uzumati
Hey guys I am wanting to built a canister similar to guzzles for the CCV tube but use the canister as a "p-trap" for the oil and on the other side vent gasses to the atmosphere and am planning on using a check vavle for this. The valve I am looking at has a 2psi cracking pressure and I am wondering if this is low enuff not to cause back pressure in the CCV system.
Anybody happen to know what the line pressure is in the CCV system?
Old Sep 18, 2006 | 09:32 AM
wilbur996's Avatar
wilbur996
What is the purpose of the check valve? I really don't see a need for it.
Does the crank case pressure ever go into negative pressure while decelerating?
Old Sep 18, 2006 | 09:45 AM
SpringerPop's Avatar
SpringerPop
Nope.
The only time that flow in the road draft tubing could conceivably flow in reverse would be while the engine (and crankcase gasses) were cooling after shutting down. That amount would be miniscule, at best, and if a longer piece of CCV hose were used (like to the rear wheels), it would be a complete "no-factor".
Pop
Old Sep 18, 2006 | 10:08 AM
Uzumati's Avatar
Uzumati
I guess what I am trying to do is purely preventitive to keep a "dirt-dober" from building a nest in the tube and clogging it. If they will build a nest in my grill they will build it anywhere
Old Sep 18, 2006 | 10:22 AM
herman2001's Avatar
herman2001
Any pics on how to start this ccv tube mod?
Old Sep 18, 2006 | 10:26 AM
Uzumati's Avatar
Uzumati
Other than an insect plugging the tube I would like to keep the oil out of the exhaust kinda like this with the check valve in the line to the exhaust (if Needed) elimianting the backpressure on the CCV sysyem
Old Sep 18, 2006 | 12:00 PM
Cuda_jim's Avatar
Cuda_jim
WHat you need is a vacuum on the ccv. I have installed these (below) on 3 diesels and numerous gassers with great results. BTW: with the check valve you can place this anywhere in the exhaust system. The check valve stops exhaust pressure from flowing into the crankcase.
https://www.ford-trucks.com/forums/a...achmentid=2680
It's a hi-perf trick for gassers but works very well on any turbo motor. IF enough vacuum is appied to the crank case there will be an increase in performance. I saw 20hp on my prostreeter.
Old Sep 18, 2006 | 12:41 PM
Uzumati's Avatar
Uzumati
Cuda that is exactly what i am wanting to do, but I want to incorporate a way to "trap" the oil before it gets to the exhaust and periodically drain it from a reservoir
Old Sep 18, 2006 | 01:42 PM
Cuda_jim's Avatar
Cuda_jim
amiller, Just curious why yuou need to trap the oil? I can't imagine there would be that much, besides it keeps the pipes from rusting , just kidding.
Old Sep 18, 2006 | 01:51 PM
Uzumati's Avatar
Uzumati
I doubt I "need" to trap it I just dont like the idea of raw oil leaking out of the exhaust. Even if it is just the small amount that comes out the CCV.
Old Sep 18, 2006 | 01:55 PM
hott-rodd's Avatar
hott-rodd
I'm thinking of a long hose to a oil trap then return the hose to the original spot.
Really just want to keep the oil out the boots.
What do you guys think?
Old Sep 18, 2006 | 02:02 PM
Uzumati's Avatar
Uzumati
Originally Posted by hott-rodd
I'm thinking of a long hose to a oil trap then return the hose to the original spot. Really just want to keep the oil out the boots. What do you guys think?
Hmmm....thats an idea no need for a long hose or exhaust you could keep everthing under the hood or close to it and not have to worry about the (uhm how to i put this nice) Aroma.
Old Sep 18, 2006 | 02:20 PM
Cuda_jim's Avatar
Cuda_jim
It'll burn up before it does that.
