1966 - 1977 Early Broncos
Bronco axle swaps
Old Sep 17, 2006 | 09:00 PM
bronco69's Avatar
bronco69
Bronco axle swaps
hey is there any heaver axles than a dana 44,to put under a bronco that will fit with out alot of refabcation? Because to day at a mud bog i snaped bouth front axles in my dana 44 and im tried of breaking axles all the time.
Old Sep 18, 2006 | 02:12 AM
fordtrucksforever's Avatar
fordtrucksforever
There are several aftermarket namebrand replacements that are much stronger than stock. Also have nearly bulletproof u-joints. The EB D44 is shorter than most other applications and limited to it or major reconstruction shortening a D60. I will try to find some specific links.
Old Sep 18, 2006 | 06:52 PM
bronco69's Avatar
bronco69
ya im going to buy aftermarket axles but what ones are the best
Old Sep 19, 2006 | 12:03 AM
RCrawler's Avatar
RCrawler
Warn offers a really strong axle shaft in a 4340 alloy.
I am running Mosers in the front of mine and have had very good luck with them. All of the upgraded aftermarket axles will come with the larger 1/2 ton size ujoints.
As FTF said it the u joints themselves are just as important as the axles. I use non greasable Spicer brand joints. They are much stronger than the typical parts store cheapies and not having grease passages in them helps with strength.
For the ultimate ujoint upgrade, the CTM's and the Ox ujoints are hard to beat. They are expensive but well worth the money.
Jason
Old Sep 19, 2006 | 05:48 PM
bronco69's Avatar
bronco69
thanks for the help , im gonna get heavy dutie u joints and axles now and see how their hold up. cus sunday the u joint blew apart and tore the axle up on the drive side, but on the passenger side the axle just twisted off. And i had this happen 4 times and im tried of it breaking in the middle of the bog and loseing my front end .
Old Sep 19, 2006 | 11:30 PM
fishmanndotcom's Avatar
fishmanndotcom
well it depends on what you think a lot of fabrication is! i swapped a fullsize D60 under the front of my 72 and it didnt really take much. bought wedges from JBG as well as the C-bushings. had to make a 1/2" spacers (the axle diameter is larger than the EB axles'). and that was it aside from shavin the axle housing down and cleaning it up! i used the stock radius arms (even though the pass side is wristed) and they fit in the stock brackets!
i think i got some pics in my gallery
-cutts-
Old Sep 20, 2006 | 07:18 PM
bronco69's Avatar
bronco69
-cutts-
Ya i though about doing that and if these new axles i get dont hold up thats what im going to do
ManfredVonRichtofen
1978 - 1996 Big Bronco
Dec 12, 2013 11:24 PM
'79 fourdoor
Nov 2, 2010 01:01 PM
f1drivr
Aug 31, 2007 01:16 AM
Cheshire Cat
15
Feb 19, 2004 04:18 AM
Greasemunkey357
Jan 14, 2004 04:12 PM
