New Engine Knocks
Old Sep 17, 2006 | 12:07 PM
desperado_18_2000's Avatar
desperado_18_2000
New Engine Knocks
I've had the new 300 in my truck for about 2 weeks now. For some reason, now on startup it has a loud distinct clack or knock that quiets down after a few seconds of running. The only thing i can think of is that the mains are trash (which they weren't before install, i checked and spec'd em.) Or the lifters are failing to stay pumped up...
I'm hoping its the latter rather than the former...as i just might seek a replacement of the big block variety.
Old Sep 17, 2006 | 07:45 PM
rhetor's Avatar
rhetor
Here's a funny one-
try puting a new oil filter on it.
Sounds like maybe your drain back valve on it is broken and you're just starving for oil up top on start up.
Old Sep 17, 2006 | 08:37 PM
desperado_18_2000
Its got a brand new FL-1A Motorcraft on it. Less than 500 miles. Though i suppose it could be possible.
Old Sep 18, 2006 | 11:33 AM
desperado_18_2000
Apparently I got the "knock" problem fixed. I guess i didn't tighten the rocker arms down properly and a couple of them were loose. I tightened those and lo-and behold the sound went away.
Now just to get the carb to quit whistling when the engine warms up.
