Sponsored by: Real Truck
tranny problem
Old Sep 17, 2006 | 12:00 AM
okcwby390f's Avatar
okcwby390f
Angry tranny problem
I have a 94 F-350 7.3 turbo e40d. It was assembled wrong. I am needing a picture of the plastic check *****, springs, and steel check ***** under the seperator plate. I have counted 10 plastic check *****, 1 spring, 1 steel check ball, and 1 needle check ball. I just need the placement of each one. this tranny would not shift into overdrive at times then it would not shift 1st through 3rd properly and woul hang in gear. All of this was before getting tranny pulled apart. after long fight to get truck back. I think they put some of the check ***** in wrong. I need any info. I can get. Thanks
Old Sep 17, 2006 | 05:15 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Kurtis, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
