Sponsored by: Real Truck
new led pics
Old Sep 17, 2006 | 09:24 AM
CounterMaker's Avatar
CounterMaker
thanks strokin...they also come in smoke and brite white...the guy said that smoked lenses only look good on black and grey truck...well your is grey so check em out
Old Sep 17, 2006 | 09:25 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the bulbs are LED, correct? i want to keep my base, i just want clear covers, and a replacement amber bulb.
Old Sep 17, 2006 | 09:26 AM
CounterMaker
Originally Posted by Tim Lamkin
Where did you get the clearence lights lenses, man that was a labor of love to do all them.
Looks great.
http://www.reconaccessories.com/?gcl...FQLTJAodXzmXJg
Old Sep 17, 2006 | 09:27 AM
CounterMaker
the roof lenses and 3rd brake light took me about 10 min total...those dam turn signals where a pain and the tailgate was hard only because i drilled it and coated the screw with silicone for addd protection!!
Old Sep 17, 2006 | 09:30 AM
CounterMaker
no i dont think...the bulbs look identicale to the oem just amber...im pretty sure leds are extremely small and these arent they are just as big as the oem clear ones
Old Sep 17, 2006 | 09:31 AM
CounterMaker
well thats all i comes with is a cover and amber replacement bulbs...i dont think they sell an aftermarket base
Old Sep 17, 2006 | 10:33 AM
6L PWR's Avatar
6L PWR
They do look awesome. I am disappointed with my line of fire in that I don't think it puts out enough light in reverse. I was hoping for more.
After your other comments, I just may drill mine out too. Sure would make it easier and last better. I was a little apprehensive thinking that the adhesive generally doesn't last that long as it is. I wish mine had clearance lights. I love the way those look. Yeah, I know I can add them, but I have other things I want to spend the money on first. Like making it faster yet. lol
Looks awesome dude!
Old Sep 17, 2006 | 01:15 PM
CounterMaker
lol...i was just looking at mine and i noticed it was a little off..the tailgate light and well im ****...soooo im going to go try and do something with it....i might just drill new holes...o well ill do a little body work!!!
Old Sep 17, 2006 | 01:51 PM
CounterMaker
well i just went out and adjusted them...i had a little play because the holes in the light bar where large enough...it looks off from the bed itself but it looks straight with the bumper...o well i guss i cant get it perfect...i wish they would make the light bar out of stainless steel rather than plastic because that plastic is so flimsy that it warps and doesnt stay straight...i think that is the proble...o well and yeah i was dissapointed in the amount of light the reverse gave off
Old Sep 17, 2006 | 02:22 PM
EnviroCon's Avatar
EnviroCon
Thanks CounterMaker. I've been waiting to see those smoked turn signals on an SD before I bought them. And looking at yours, I think I'm going to have to get them.
I'd like to add a couple of things, just in case someone does a search.
1. The smoked cab lenses also look good on the dark green trucks (at least I like the way they look on mine).
2. When I installed the cab lenses (from RECON) I had to carefully remove the foam type gaskets from the OEM's to reuse them in the new lenses since they didn't come with them. So be careful when removing the old lenses, that gasket likes to stick half to the base and half to the lense.
And the new amber lights for the cab are bulbs not L.E.D.'s
Old Sep 17, 2006 | 05:09 PM
CounterMaker
yeah they arent LED...and as far as the foam gaskets...it stuck to my first one and i didnt notice it and almost put it away with the old lenses...and by the way...with the tailgate light...im so **** i actually coated the screw on the oppisite side and the hole i messed up on ...where it is sticking through... with silicone....i dont think it will rust now..!!!
Old Sep 17, 2006 | 06:55 PM
04superduty's Avatar
04superduty
looks good coutermaker. i didnt know recon sold replacement mirror turn signal lenses.
Old Sep 17, 2006 | 08:37 PM
  #28
Superdutyfreak's Avatar
Superdutyfreak
Thumbs up
CounterMaker,
You finally went out and purchased the mirror lenses. WOW...They look great. As I told you, it would be a little tricky with the install, but not too bad. It was well worth it..Good luck with everything, and your truck looks awesome...
SD Freak
Old Sep 18, 2006 | 03:48 PM
  #29
CounterMaker
Originally Posted by Superdutyfreak
CounterMaker,
SD Freak
thanks...just 2 things im concerned with...the hole i put in the wrong place while drilling for the tialgate light...i drew a line on the truck where i wanted the hole and i put the hole on the wrong side of the line...well i put a little bit of paint on the hole and then put the light on and it covered it then i went to the oppisite side and smeared some silicone on it...o well such is life...and the other thing i just noticed today was the mirror lenses dont fit quite as tight as the factory...obviousley...you cant see where it doesnt fit tight...it looks like it fits perfect but you can surely hear the whistle when you get at about 40 mph from the wind...any suggestions?
Old Sep 18, 2006 | 04:09 PM
  #30
Superdutyfreak
Funny you say that. My friends did the same thing, and he re installed them and no problems. You must make sure that ALL of the clips are secure and that they are clipped tight, or else you will get some air noise.
