vin plate/ id card?
Old Sep 16, 2006 | 07:24 PM
DNewton's Avatar
DNewton
vin plate/ id card?
the plastic sticker on the drivers door panel is not there anymore, but i did happen to find a plate under the hood, can you guys decipher it? ill write it as it is on the plate
8927 11 f25 B48078
51 XT330P ACCL
SSROM6ECLMDA MP
MASC. DE HL HT CB
I HAVE NO IDEA WHAT THIS IS, ANY INSIGHT IS APPRECIATED! Dustin
Old Sep 16, 2006 | 09:14 PM
PLC7.3's Avatar
PLC7.3
That one makes no sense other than the F25 which is F250... try the vin number under the windshield.
Position 1,2, and 3- Manufacturer, Make and Type
Position 4 - Brakes/GVWR Class
Position 5,6, and 7- Model or Series f25 = F 250
Position 8 - Engine Type
C or K - IDI
F - DI
I or M - DSL
Position 9 - Check digit
Position 10- Model Year 1994 - R
Position 11- Assembly Plant
Position 12- Constant "A" until 99,999 is reached when "B"
Position 13 through 17 Sequence number begining at 0001
IDI - Indirect injection (turbo diesel)
DI - Direct injection (turbo diesel)
DSL - Diesel
Old Sep 16, 2006 | 10:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The B48078 probably matches the last 6 digits of the VIN number.
Where did you find that plate?
Old Sep 16, 2006 | 10:44 PM
DNewton's Avatar
DNewton
it is bolted to my firewall right behind ware air cleaner, ill get a picture of it up in a few mins!
Old Sep 16, 2006 | 10:58 PM
DNewton's Avatar
DNewton
heres pic#1
Old Sep 16, 2006 | 10:59 PM
DNewton's Avatar
DNewton
heres pic#2
Old Sep 17, 2006 | 11:35 AM
PLC7.3's Avatar
PLC7.3
Without the door post label any time you need axle info you need to physically look for the attached axle label and copy down info, same with trans etc. Once you have that info your set......
atomicjoe23
Mar 10, 2010 01:03 AM
TwoX
Jun 18, 2007 08:50 PM
BlueDolphin
Aug 31, 2005 12:21 PM
shakespearesdad
Texas Chapter
Dec 15, 2002 07:23 PM
