Stock Differential?
Sep 15, 2006 | 08:51 PM
Stock Differential?
I can't pull any casting #'s off my differential, but if it is original, (Eng and Tranny aren't) would my truck accelerate like a mother, and burn rubber with the 320 ft-lbs of torque and 210 hp of a 302? Is it likely a differential swap happened with the rest of the swap, or would you think it stayed in?
Digging the pink?
Sep 15, 2006 | 09:59 PM
The stock differential had some very low gearing...lots of bottom end with no top end.
Sep 16, 2006 | 12:25 AM
Pull the cover and count the teeth on the ring gear. I doesn't take long and you never know what else you will see in there.
Sep 16, 2006 | 06:12 AM
Sep 16, 2006 | 11:53 AM
What is wrong with my pink. I think that is what happens when I don't have my dinner on time...
Sep 16, 2006 | 03:31 PM
Well it's like this, if I see it again I will just ignore your posts.
And
Yes I am one.
Sep 16, 2006 | 05:22 PM
Quote:
I don't know - I think it gives the forum a sorta flair - like Victoria's Secret
Sep 16, 2006 | 08:06 PM
Thanks for reminding me to check my stock of Pepto Bismol.
