power brake conversion
Old May 9, 2001 | 09:56 PM
66_390 mike's Avatar
66_390 mike
Old Jun 20, 2001 | 08:32 PM
harvey's Avatar
harvey
I have a 66 F100 with manual brakes and a single master cylinder. I intend to replace it with power brakes and a dual master cylinder. Will I require a proportioning valve (is that the right term?) with the new setup? Do I have one now and just not realize it? How do you adjust the valve to get the correct front and rear pressure?
Thanks,
Harvey
Old Jun 20, 2001 | 08:43 PM
jowilker's Avatar
jowilker
Harv, your question has been discussed many times here. Check through the archives, and if you still have questions, we'll help. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Jun 20, 2001 | 10:26 PM
impact's Avatar
impact
When converting to power steering i know the columns are different lengths but can it work? i have a 3spd on the column but want power steering
Old Jun 22, 2001 | 11:30 PM
ole65's Avatar
ole65
You don't need to bother researching a proportioning valve, it is only used when you put disc brakes on the front and have the drums in the rear. Drum brakes all around don't need the valve to 'distribute' the line pressure. It is a terrific idea to go to the dual bowl master cylinder; the power booster will make the stops alot easier.
Lee
1965 F100 short box styleside
