switching motors...help!
Old Sep 14, 2006 | 07:46 PM
dustinetter's Avatar
dustinetter
Exclamation switching motors...help!
hello
i have a 1992 f-150 that has a bad motor and a 1978 f-150 that has a good motor. i was wondering if anyone knew if it was possible to switch those motors out? i dont think it would be a problem but i knew the wiring would be a pain and the 92 is fuel injected and the other ones not, obviously; but i think that wouldnt be too much of a problem. but anyways..what do u guys think or what? because i really dont know
Old Sep 14, 2006 | 08:00 PM
Steamir's Avatar
Steamir
Imho, I think the unintended consequences will sneak in with the wiring and computer stuff.
o7dgm's Avatar
o7dgm
the 78 would be easy enough to change over. but how strict are the emission laws where you live ?
Old Sep 14, 2006 | 09:04 PM
00bucker's Avatar
00bucker
Smile switch motor
First of all if it is the same motor, i would just switch manifolds and be done w/ the computer stuff. You shouldnt have a problem after that.
Old Sep 14, 2006 | 09:11 PM
andym's Avatar
andym
Are you wanting to transplant the whole EFI system or wanting to just put the carbed motor in the truck? In some states this is a no-no emissions wise.
It can be done, but it will be an enormous pain. You might consider heading over to the junkyard and picking up a motor there for $400 or so.
Old Sep 14, 2006 | 09:36 PM
dustinetter
i was just wanting to put the carbed motor in the truck that had the efi. i personally dont wanna mess with it, but my dad thinks that it would be a good idea.
Old Sep 14, 2006 | 10:00 PM
EPNCSU2006's Avatar
EPNCSU2006
Do you want to swap the EFI to the older engine in the newer truck or run it on carb in the newer truck?
Old Sep 14, 2006 | 10:17 PM
dustinetter
run the carb on the newer truck.
Old Sep 15, 2006 | 01:04 AM
EPNCSU2006's Avatar
EPNCSU2006
I'd think that it would be just as easy, if not easier to just swap the EFI to the older engine as it goes into the newer truck than it would be to convert the 92 to run on a carburetor. That's just my opinion though....
Old Sep 19, 2006 | 03:58 PM
gustang818's Avatar
gustang818
I agree with Eric. It would be much easier to keep the truck EFI. Just put the EFI manifold on the carb motor and drop it in and you're done. If you go with the carb in the EFI truck, you have a lot of changes to make. I can think of a couple big ones: the carb wants 5-9 psi fuel pressure, you have 40 lbs with the efi (new fuel pumps or regulator w/ return); your trans, if an E4OD, will not shift without input from the EFI sensors unless you buy an expensive tranny controller.
Old Sep 19, 2006 | 04:32 PM
frederic's Avatar
frederic
Move EFI heads, intake, bracketry and wiring to old engine. Install. Plug harness and fuel lines in.
Start truck.
Old Sep 19, 2006 | 05:25 PM
dustinetter
well there might be a problem with that. the old engine is a 302 and the new engine is a 351..will the manifold and all that stuff still transfer over?
Old Sep 19, 2006 | 05:33 PM
EPNCSU2006's Avatar
EPNCSU2006
If it's a 351M, you are going to have more issues than just converting to carb (need different transmission, different engine mounts, accessory brackets, etc). The 302 intake won't work on either 351M or 351W.
Old Sep 19, 2006 | 06:51 PM
andym's Avatar
andym
Yeah, all this was under the assumption that you were switching out motors that are the same.
I am not a 70's truck expert, but I don't think the 351W was available from the factory in a truck. I think they were car-only engines back then. Doesn't mean someone didn't put one in, though.
If it is a 351M (likely) then you have a significantly more complex project.
Old Sep 19, 2006 | 08:15 PM
00bucker's Avatar
00bucker
Your dad has a good point!!! Alot less work. And just as good. You get more HP with the carb.
