Sponsored by: Auxito
airbag code 2/7
Old Sep 14, 2006 | 12:48 PM
BMARBLE's Avatar
BMARBLE
airbag code 2/7
airbag light on dash flashes code 27. Checked bulb in passenger switch but was okay, also fuse number 22 was okay. Any other suggestions?
Old Sep 14, 2006 | 06:13 PM
screwy's Avatar
screwy
Check for loose connections to the switch. How did you test the bulb?
Old Sep 15, 2006 | 08:29 AM
projectSHO89's Avatar
projectSHO89
LFC 27 is for a burned out bulb in the PAD.
Does the light come on when the passenger side airbag is turned off?
You may have a bulb that is on the verge of complete failure....
Steve
Old Sep 15, 2006 | 02:08 PM
BMARBLE's Avatar
BMARBLE
I checked the bulb by visual inspection only, the filament looked fine. I did take back apart and used a meter on the bulb and it was bad. Replaced the bulb and everything is fine. Thanks for the help.
