Modular V10 (6.8l)
3rd repair for engine light
Old Sep 13, 2006 | 04:53 PM
shirkf7's Avatar
shirkf7
well,i just got my 04 f250 back from the dealer for the 3rd time for od light flashing & engine light on,also vibration"still there"..they said they changed a turbine sensor? & its on the output shaft of the tranny...i hope this does the trick,i bought the truck a month ago & has been at the dealer 2 weeks..i like the truck & wouldnt mind doing a couple mods,but still under warranty & if it dont get fixed soon i might have to get my$$$ back & go shopping for another.
Old Sep 13, 2006 | 07:34 PM
NoMo's Avatar
NoMo
Good luck with this latest repair attempt... hope it does the trick.
Once everything gets straightened out, you'll love the truck.
Old Sep 14, 2006 | 08:59 AM
captchas's Avatar
captchas
Guest
that is the foward senser on the top of trans cases that senses input speed from the convertor input shaft /foward drum and they are known for problems on the 4r100 unit. but the 3 rd time i doubt it . maybe they over looked a bad wire the last few times
Old Sep 14, 2006 | 05:42 PM
shirkf7's Avatar
shirkf7
ok,thanks for the info,,this was the 1st time they actually found a problem,i should also mention the 1st time was at a different dealer that erased the code.so hopefully it was properly diagnosed this time around as both dealers said they would mail me a copy of their work invoice??
