water in oil?
Old 09-13-2006, 12:59 AM
ahopper's Avatar
ahopper
ahopper is offline
water in oil?
ok so this is my first time posting for a gas engin. i will come right out front and tell you i know just about squat about gas engins. im a diesil guy. my dad has a 1997 f-150 with the 4.6l. the otherday it started running real ruff and then the check engin light came on. well i then took it to auto zone and had them run the code. they said the #4 cylinder was missfiring. so they said it could be either plugs or plug wires. so i went home and put new plugs in. the first spark plug boot i pulled( #1) had what looked like and smelled like anti-freez on it. i had no clue.so the rest on that side of the engin was the same except the #4 which had water stuph on the inside of the boot. the otherside was all dry. now my question is could ther be water in my oil or what could happen i just have no clue i had the engin light erased and hasnt come back on yet. the truck also has only 87000 miles on it. sorry for it being so long
Old 09-13-2006, 05:10 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome ahopper, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 09-14-2006, 01:25 PM
ahopper's Avatar
ahopper
ahopper is offline
can anyone help?
Old 09-14-2006, 01:33 PM
92merc's Avatar
92merc
92merc is offline
I thought there was a coolant line that can leak once in awhile on that side? Heater hose or something. Just double check all the hoses and make sure it isn't dribbling onto the heads.
Old 09-14-2006, 02:18 PM
skilife17's Avatar
skilife17
skilife17 is offline
Check the heater hose that runs directly above the #4 cylinder and check to see if it is tight.
Old 09-14-2006, 10:47 PM
ahopper's Avatar
ahopper
ahopper is offline
no it doest seem to be leaking, but its not onlycylinder 4 its all four on the one side just the #4 was the worst and thats wher i got the missfire code on
