slow to start (sometime)
Old Sep 14, 2006 | 08:50 PM
BuickTurbo's Avatar
BuickTurbo
One of your batteries is on it's way to Vegas. Did you load test them indevidually? (not in series)
I have had this happen before, and currently it is happening again. Indevidual load test shows that the passenger battery is really.....really weak.
Old Sep 14, 2006 | 09:24 PM
jtharvey's Avatar
jtharvey
Originally Posted by shad
harvey,,,,, i've already thought of the HPOP being low of oil,, would the low pressure pump be the problem with only 57,000 well maintained miles.
I tested the batterys with my Snapon battery tester
Well, with only 57K, I would not think that the LPOP would be going out already...but I've seen stranger things happen. I doubt it's the problem, but I wouldn't completely rule it out just yet. Symptoms are what happens when the LPOP is beginning to fail. I'd just test it, so you can rule it out. Get a mechanical gauge, install it where the oil pressure sensor is now (top of the HPOP res), and watch it while an assistant cranks. Do this before the first start of a day, when the truck typically has trouble starting. Watch the pressure, and if it takes some time to build, then suddenly fires, you may have found your problem.
Before you do that though, you can remove the sensor and look down in the resivoir before first start to be sure it is full of oil.
If you didn't do it already, try what Dan suggested, and load test the batteries individually.
Old Sep 15, 2006 | 12:05 AM
05f250fx4's Avatar
05f250fx4
when i replaced my starter the truck started up like it was brand new. now after 3 months, its a lot slower to start up. how can i get my truck to start up like it was brand new? also when i replaced the batteries the truck started up quick too, then gradually started more slowly.
Old Sep 15, 2006 | 01:09 PM
BuickTurbo's Avatar
BuickTurbo
I may have forgotten how to spell individually. I'm ok now.
Old Sep 15, 2006 | 08:18 PM
shad's Avatar
shad
I wish i had a shop with atleast 1 60watt light bulb. when you work from can to cant it's hard to find the time to trouble shoot.
Old Sep 15, 2006 | 08:55 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Did you try the batt swap?
Old Sep 16, 2006 | 12:38 PM
shad's Avatar
shad
got in it this morning , crank crank and no start. changed the batterys and it started right up. felt really great that problem was solved. BUT,,, about 3 hours later while driving in town started loosing power, missing. DASS me, realized aux. tank in bed was empty, switched to main tank. it never died but after 10 miles still misses, shakes the whole truck sometimes. any ideas ???
Old Sep 16, 2006 | 12:56 PM
Uzumati's Avatar
Uzumati
Trash in bottom of tank (now in fuel filter) or air in the lines (should work itsself out) maybe.
If tach is dropping suddenly when it "misses" kinda points back to CPS'ish issue
Old Sep 16, 2006 | 05:10 PM
jtharvey's Avatar
jtharvey
Good the starting issue is worked out. I'd say air in the lines is causing the shaking. It can take some time to work it's way out. Give it 100-200 miles.
Old Sep 16, 2006 | 08:53 PM
shad's Avatar
shad
never thought 1 weak battery would cause truck to no start. i have a 96 350 that i ran with only 1 batt for over 6 months and never a start problem.
Old Sep 16, 2006 | 08:58 PM
Tenn01PSD350
The bad one will drain the good one like a vampire.
Old Sep 16, 2006 | 09:15 PM
Uzumati's Avatar
Uzumati
I cant prove it but after getting up close and personnal trying to learn the electrics of the powerstroke I believe that other than just a weak battery draining the good one a short at the cell level of one battery can cause a ground loop and really cause havoc with the computer control systems. A cell level short can be very hard to find and diagnose as sometimes the only indication being a slight drop in amperage output depending on the health of the other cells.
Old Oct 7, 2006 | 09:24 PM
  #28
forumsearcher's Avatar
forumsearcher
Did changing the batteries finally solve your problem?
Was the stalling you experienced simply running low on fuel? Did this correct itself with time?
Old Oct 9, 2006 | 08:11 PM
  #29
shad's Avatar
shad
yes ,,, changing the batterys did it . did a load test after both batt disconected 1 batt checked 12+ volts, 1 checked 6+ volts. this load test was done after 18 hours with out being started and 2 long cranking trys.
Old Oct 9, 2006 | 08:16 PM
  #30
shad's Avatar
shad
i ran the truck out of fuel!!! DASS me should have already known what the problem was
