to drain the HCFM?? How long do I let it run out? Diesel is clear so i dunno. I looked at the tech post but it just says how to do it....not how long. I have it draining out right now.
Usually just a few seconds will release the bit of water in there. Next time hold a paper cup or similar. Catch what you can. Have a look, if there is water you will see the difference in color.
There may have been a TSB for it but mine did the same thing; long story short there was a problem with the sensor in the HCFM, got it replaced and no problems since.
...enough...is just before and immediately prior to ...to much.
Just thought you oughta know.
I would tend to disagree...I was told that a container this big made from Unobtanium and the precise amount of Eleventy-Two ounce-liters is what the proper engineering call-out is for this and those procedures.
Sorry...Very late and deep into a GreyGoose bottle(smarta$$ juice) told me to post this!
