Stock collant temp guage
Old Sep 12, 2006 | 06:57 PM
Reidicus's Avatar
Reidicus
Where does your temp guage sit when idling? I just got the Hypermax500 head gasket and ARP head bolts installed. Mine sists exactly in the middle. Same as before with stock parts (blown head gasket). I am guessing this is normal. Any input would help. Thanks!
Old Sep 12, 2006 | 07:01 PM
BarebackJD's Avatar
BarebackJD
that's where mine sits.
Old Sep 12, 2006 | 07:02 PM
Reidicus's Avatar
Reidicus
Ahh good to hear. Now I just have to wait untill I do some towing and see if it overheats.
Old Sep 12, 2006 | 11:50 PM
2005 Ford's Avatar
2005 Ford
Mine sits dead nuts in the center as well
Old Sep 13, 2006 | 10:00 AM
bczolone's Avatar
bczolone
What the temp supposed to be? I just got a ScanGauge 2 and mine gets to 190F and thats where it stays give or take about 2 degrees...I haven't towed with it yet though.
Old Sep 13, 2006 | 06:33 PM
Mwachel's Avatar
Mwachel
With my Scangauge2 in the Excursion 6.0....Mine fluctuates from 180 to 220 depending on the temps. 180-190 in the morning going to work (80 outside). About 200-209 coming home from work (freeway, 100+ outside). I have seen it hit 220-225 pulling 4000lb trailer up a big grade at 70 mph when the temps are 107.
With all that fluctuation...the stock needle NEVER moved a bit!
Let me tell you...I thought my truck was going to take off when that fan kicked in full speed!! WOW.
Old Sep 13, 2006 | 06:40 PM
BarebackJD's Avatar
BarebackJD
It should be right around 190. All our JD thermostats are 190's and other trucks as well.
