Rear end
Old Sep 12, 2006 | 04:42 PM
1990 f-150's Avatar
1990 f-150
Rear end
I have a 1990 f-150 automatic, and I was wondering how can I tell what kind of rear end gear ration is in there.And I was wondering if changing you gears is a diy project, if so would I use the stock shims in the rear end. thx
Old Sep 13, 2006 | 02:09 AM
monsterbaby's Avatar
monsterbaby
Welcome to FTE.
look on your differential cover bolts for a tag, it should have 2 lines on it configured like this
XXX-XX #XXX
#.## #.# XXX
The first line is illrelevant for what your wanting to know but the first 2 groups are an aplication code, and the last group of 4 is the build date
Second line is what your wanting to know, the first group is your gear ratio should be something like 3.73 or 3L73, if it has the L it's a limited slip if not then it's an open diff, the second group is the axle in your application it should probably have 8.8. The last group is just a plant code.
Old Sep 13, 2006 | 07:42 AM
kotzy's Avatar
kotzy
If you change the gear set you will have to reset the pinion depth and the lash and carrier preload this means changing shims. My own advice would be leave it to someone who has the tools and assortments of shims to set it up or you will be
unhappy with the noises you end up with.
Old Sep 13, 2006 | 07:45 PM
1990 f-150's Avatar
1990 f-150
thx for the info
Old Sep 13, 2006 | 07:54 PM
1990 f-150's Avatar
1990 f-150
I looked on the bolts and there was no writing on them maybe due to being 16 years old,but I did find a number on the side of the axle ETTW-4025-BA, or ETTW-4026-BA, or, ETTW-4026-8A,or, ETTW-4025-8A, its hard to tell aprt the 8 and the B and the 5 or the 6, what does this number mean, and can where can i find out what it means
thx
Old Sep 14, 2006 | 05:04 PM
andym's Avatar
andym
Those are just part numbers.
You can also look at the sticker on the driver's side door jamb. There's a code for axle:
18 - 3.08
19 - 3.55
H8 - 3.08 limited slip
H9 - 3.55 limited slip
7.3stroker2215
Mar 30, 2022 11:58 AM
Mike Morrison
Jan 12, 2016 06:50 AM
Shermanator213
Aug 30, 2015 08:50 AM
Johnnie T
Apr 11, 2011 06:59 PM
1990Fordf150v8
17
Oct 28, 2003 10:03 PM
