'99 7.3 Air Filter Question
Old Sep 12, 2006 | 03:20 PM
SCOTTY STA-28's Avatar
SCOTTY STA-28
I Replaced My Filter Today And As Usual I Had A Little Trouble Getting The Top Of The Box To Fit Back On. In The Process, I Broke One Of The Slots The Tab FROM THE TOP Is Supposed To Fit Into. Do I Need To Worry About A Good Seal And If So Should I Just Replace The Whole Thing With An Aftermarket Unit?
Old Sep 12, 2006 | 04:58 PM
zx250's Avatar
zx250
Of the next Riffraff East
My recommendation is loss the stock box and filter all together. Many 7.3 owners here have seen engines and turbos dusted due to ill fitting factory filter boxes. A lot of members here use NAPA 6637 open air filter as a replacement. I will offer you all the air your engine can use and is very inexpensive. ($20-40) and last for 20k or more. Do a search for 6637 or Kwik filter on search feature here. Very easy to do.
https://www.ford-trucks.com/forums/2...ght=kwikfilter
This will get you started.
EDIT: Wecome to FTE. Hang around here and you will learn things about your truck you never knew. Welcome aboard. You will also want to check out the forum just for the 7.3's. https://www.ford-trucks.com/forums/forum31/
Old Sep 12, 2006 | 06:10 PM
Beast12's Avatar
Beast12
Thread moved to 99-2003 7.3L Power Stroke Diesel engine forum.
-Matt
Old Sep 12, 2006 | 07:57 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The stock box doesn't seal very well when it's installed correctly and not broken. It definitely will be worth your time to check out some of the aftermarket alternatives.
Old Sep 12, 2006 | 08:06 PM
Muktown's Avatar
Muktown
you can have my stock box and i even have a brand new filter for it. let me know if you want it or not
Old Sep 13, 2006 | 11:38 AM
Mark at DPPI's Avatar
Mark at DPPI
SCOTTY STA-28,
Do yourself and your truck a favor and get an AFE STage II Pro Guard 7 system. You'll love it! If you have any questions on it let me know.
Mark @ DPPI
Old Sep 13, 2006 | 12:19 PM
roaky81's Avatar
roaky81
Ford's AIS heavy duty air filter system is around $200. Not sure how it compares to other systems, but I like it. I think I got it from powerstrokeshop. Others have gone from the 6637 filter to the AIS. Ask Kwik if he noticed any differences (besides being quieter). It takes about 30 minutes to swap out.
Old Sep 13, 2006 | 01:02 PM
Car_nut57's Avatar
Car_nut57
FTE *******
Replace it with a Ford AIS. They have the best filtering available and will flow plenty of air with a foam fender sleeve.
Old Sep 15, 2006 | 09:21 PM
Muktown's Avatar
Muktown
i have a kwik filter right now but if i diddnt have to pay for college i would go with an ais
Old Sep 16, 2006 | 07:51 AM
Uzumati's Avatar
Uzumati
No Complaints on the AIS here
