CPS fixed but now somthing else is wrong
Old Sep 12, 2006 | 01:38 PM
dirttoo's Avatar
dirttoo
I did my CPS yesterday and all seems well there. Today on a test drive my seat belt/air bag light was on, then when I shut the truck off I noticed a clicking sound from under or behind the dash. I also noticed the blower motor was still running even with the key completely out of the ignition. I doubt these are related to the CPS but I don't know. Can anyone help diagnose this one? All else seems OK. Thanks, Marty
Old Sep 12, 2006 | 06:18 PM
Uzumati's Avatar
Uzumati
turn the key on and count the air bag light flashes. there should be a group of 2 numbers repeated 3 or 4 times then post the results.
Blower on with key out??? is your ignition cylinder worn out where you can remove key with out turning it off.
Old Sep 12, 2006 | 09:14 PM
dirttoo's Avatar
dirttoo
The key turns the radio and wipers off but not the blower motor. I will count the flashes in the morning.
Old Sep 13, 2006 | 12:31 PM
dirttoo's Avatar
dirttoo
The light is actually just the air bag light and it just stays on with no flashing. Could it be related to the blower staying on? They both happened at the same time. Thanks for help.
Old Sep 13, 2006 | 12:36 PM
ryaneverk2's Avatar
ryaneverk2
Maybe you have a stuck relay. Check the owners manual to see which relay goes to the blower motor, and investigate.
