NEED help ASAP!
Old Sep 27, 2006 | 03:01 PM
  #31
fusioncom's Avatar
fusioncom
I shouldnt have any vacuumm leaks. I replaced all with the new carb, the only one that may leak some is the PCV valve.
I'll try 10 degrees and see how that goes. Thanks!
Old Oct 6, 2006 | 08:21 PM
  #32
Steamir's Avatar
Steamir
Did ya figure it out?
Old Oct 6, 2006 | 10:02 PM
  #33
nessound's Avatar
nessound
This almost sounds like an accelerator pump issue. Next time it acts up, turn the key off and put it in your pocket. Then remove the air cleaner and look down the carburetor. Open the throttle and look for gas squirting into the center. If none you've found the problem. have you taken the carb apart? The weight or the check ball for the accelerator pump may be missing.
Old Oct 7, 2006 | 03:00 PM
  #34
woodbutcher05's Avatar
woodbutcher05
With the moisture condensation on the base of the carb and the intake manifold.It sure sounds like an iceing problem.Make sure that you have adequate carb heat or it will only get worse come winter.
Leo
Old Nov 25, 2006 | 12:04 AM
  #35
Nick_F150's Avatar
Nick_F150
If it is a TFI ignition replace the TFI module...
Old Nov 25, 2006 | 08:13 AM
  #36
sail's Avatar
sail
I guess you solved the prob.. I was goining more toward a crack in the head. Just a thought.
68f10059
34
Oct 15, 2013 11:06 AM
a.mcewan
Nov 18, 2009 08:02 AM
Drgslayr
1983 - 2012 Ranger & B-Series
Jul 16, 2009 02:49 PM
1970f2504x4
22
May 14, 2004 04:18 PM
Seifferlein
Oct 10, 2002 09:03 PM
