Had I known...
Old Sep 12, 2006 | 05:55 AM
old fool's Avatar
old fool
Had I known...
I wouldn't have so happily taken a torch to the rear fender bolts when I removed the fenders oh so long ago. What holds those suckers to the bed sides, Kryptonite? What's the best way to remove rear fender bolts from the bed sides on a 50 F1?
Thanks
Lance
Old Sep 12, 2006 | 06:33 AM
barry's Avatar
barry
THey're pinch welded to the sides. They sit in a square hole. They are hard to remove without distorting the sides. Look thru the archives for this subject, it's been discussed many times.
Barry
50 F-1
Old Sep 12, 2006 | 07:44 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If it's any consolation, they would probably broken off anyway. I had good luck drilling thru them from the inside and using a plain hex bolt.
Old Sep 12, 2006 | 09:22 AM
texan2004's Avatar
texan2004
I ground the heads off of mine (Very carefully). As stated above, almost all broke off when I tried to remove the nut.
