2.3 Engine
Old Sep 11, 2006 | 11:34 PM
MountainDreamer's Avatar
MountainDreamer
2.3 Engine
Does anyone know what year ranger started using the 8 spark plug 2.3 4 cylinder. Also, are there any differences between the 2.3 fuel injected from 1986 and 1991. I found a 1991 and was thinking of replacing the cooked motor on my 86 4x4.
Thanks for any help
Old Sep 12, 2006 | 09:19 AM
BSmitty's Avatar
BSmitty
IIRC the 8 plug head was first introduced in '89 when EDIS was introduced. '89-up 2.3ls had roller cams, and the main journal size was reduced in '88. An '88 would work fine, anything newer will not, the boss in the block for the distributor was sealed when EDIS came into production. FYI, late production '85s also had EFI, but you can use the block from back as far as you want, as long as you use your truck's head.
Old Sep 12, 2006 | 05:41 PM
G2IC_Wraith's Avatar
G2IC_Wraith
I have the 88' (4 plug) 2.3L EFI setup, and it has a roller cam.
Old Sep 12, 2006 | 09:40 PM
sfcwoodret's Avatar
sfcwoodret
I know the new ones have excellent power for a 4-banger.
Old Sep 13, 2006 | 03:11 PM
MountainDreamer
Thanks.
So the motor out of the 91 won't drop into the 86 2.3 spot? Was hoping to do a fairly clean swap out.
GeorgePBurdell
Jun 12, 2015 10:38 AM
hypnotist
Feb 23, 2015 08:32 PM
hypnotist
Nov 8, 2014 01:43 AM
freevan
Sep 13, 2014 02:12 PM
