Bed floor and supports
Old Jul 17, 2001 | 06:44 PM
Rosati's Avatar
Rosati
Since the vast majority of the 61-66 trucks have the front of the styleside bed rusted out, has anyone found replacement parts?
I found out the JC withney has patch panels but I don't know if the ribbing would match up or not.
As an alternative, I thought about replacing the ribbed metal with wood and leaving the flat panels alond the sides. I think it's possible but i would need the support members first.
Any suggestions?
Krosati
Visit my homepage at ClubFTE
http://www.clubfte.com/users/krosati/
Old Jul 17, 2001 | 10:10 PM
Russell Leonhardt's Avatar
Russell Leonhardt
KROSATI,that panel from JCW does not come close to the bed floor of a 65.Sorry Russell
Old Aug 19, 2001 | 12:19 AM
CustomCab4x4's Avatar
CustomCab4x4
[font size="1" color="#FF0000"]LAST EDITED ON 19-Aug-01 AT 01:19 AM (EST)[/font][p]I had to make a repair panel for the front of my 64. It was pretty easy since it's all flat (no ribs). A sheet metal shop can whip you one out in no time. I'll send you the dimensions if ya want.
The bed floor was another problem. I found a NOS complete floor at a swap meet, but didn't like the $600 price. I did some measuring and found that the ribbed center part on the 64-66 floor is the same size as the floor in my 81 F-150. The ribs are different and the mounting holes are to, but that piece would be easier to get ($) and install if you want a "stock" look. I ended up using flat 1/16" steel since I'm going to put in a sprayed in liner anyhow. Also, be advised that cutting out the entire floor and welding in a new one is a BIG job. Good luck, Phil
Old Aug 19, 2001 | 08:43 PM
Franklin2's Avatar
Franklin2
Racerguy
1997 - 2003 F150
214
Jun 10, 2025 07:58 AM
Racerguy
1997 - 2003 F150
661
May 17, 2022 07:37 PM
Spktyr
24
Jun 9, 2019 07:32 PM
mwlucas
Aug 30, 2017 02:44 PM
F250Rob
Aug 1, 2004 10:15 PM
