97 fuel filter
Old Sep 11, 2006 | 06:33 PM
97F350PowerStroke's Avatar
97F350PowerStroke
Best chip for 97
What have people used that gives best MPG and best HP gains. I have a manual tranny so not worried about shift points.
I was looking at the "Juice" line...? Anybody heard of Quadzilla "Zillaraitor" chips?
Just starting my research so any help would be nice.
Old Sep 11, 2006 | 06:41 PM
1997F-350's Avatar
1997F-350
pull of that big powerstroke plastic engine cover. under it you will see click here>>>>> this bad boy with the black lid <<<< click here use a screwdriver to remove the lid. drain diesel by using the yellow lever. do it ON SOME DIRT YOUR FIRST TIME so you can see where the drain tube is. that way next time you can pur some 3/8 fuel line on it and drain into a container. not reqd to drain during filter change but i like to. coat new gasket with diesel and put er back in. the cheapest place for fuel filters is fleetfilter online. same one that ford and napa sell its a wix.
Old Sep 11, 2006 | 06:46 PM
97F350PowerStroke
Thank for the reply i acutally changed my original post cause i found the answer to my question on an earlier page!! Now what do you know about my new question...
Old Sep 11, 2006 | 06:49 PM
1997F-350's Avatar
1997F-350
hhhmmmmm
manuals i like manuals....
ok here you go$$$$$$$$$$$$$$$$$$$$$
gauges
intake
exhaust
flip chip you may kick yourself later if you get one of those you stated.
sbc con ofe clutch
BIGGER INJECTORS!!
beleive it or not all this money got me 3 more mpg and about 150 more rwhp.
Old Sep 11, 2006 | 09:05 PM
97F350PowerStroke
already have aFe stage 2 intake and aFe turbo-back exhaust. just replaced the dual-mass flywheel and upgraded clutch to larger friction plate and components.
next id like to get EGT and Pyrometer guages soon.
How big increase on injectors? I know there not cheap
Old Sep 11, 2006 | 10:46 PM
1997F-350's Avatar
1997F-350
well i got stage 1's. 160cc
stock 98cc unless you got a cali truck. sounds like your there on the mods just gotta step up to the plate.
a stock federal truck puts down about 175 at the wheels. my truck is somewhere in the 300-350 range. gotta hit a dyno soon!!!!!!!
the injectors make a night and day difference. they go from turds to super stroke coal rolling tire burnin beasts that dont wanna stop...
Old Sep 12, 2006 | 10:44 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
I got the stage ones from beans and it was only $800 to have them rebuilt.
Definatly get the gauges before the injectors. Its not to hard to raise the temps and boost with bigger injectors.
