Codes 1131, 1151?
Old Sep 11, 2006 | 08:46 AM
cr_expyeb98's Avatar
cr_expyeb98
Codes 1131, 1151?
98 expy, 5.4 80,000 miles
Have been chasing 0171,0174 codes, and I replaced I believe the correct vaccum line off the PCV that indeed was split. That was Thursday(?). Reset the CEL.
The truck will still not idle for squat, which it really would not do since the CEL came on, and someone suggested the IAC.
Took the truck out this weekend about 150 miles roundtrip, and the CEL finally kicked back on. Back to AZ and now get 171,174 plus 1131, 1151, which I belive to be Lack of H02S11 and H02S21, Switch Sensor indicates lean.Any ideas on this? I have not installed the IAC or TPS, which I bought to be sure.
Could it actually be the MAF, which I cleaned originally with MAF spray cleaner, or am I the 1 in a billion that had two 02 sensors go at the same time?
Old Sep 11, 2006 | 11:35 AM
cr_expyeb98
I replaced the IAC because of the mileage, and someone on here said between 50-60K expect to have to .
No improvement.
oachs83
Mar 6, 2022 12:51 AM
apache84
Jan 23, 2017 10:21 AM
gnoon
May 24, 2016 11:23 PM
SteevenH
1997 - 2003 F150
Mar 29, 2014 12:20 PM
Phredawgy
Sep 14, 2006 04:34 PM
