Sponsored by: Real Truck
leaf spring interpretation please
Old Sep 11, 2006 | 08:26 AM
burgf250's Avatar
burgf250
I have a 2004 F250 V10 CC 4x2 which lists the spring codes as HHPP. Anyone out there who can help me interprete these (load capacity or other variables)? Thanks.
Old Sep 11, 2006 | 10:29 AM
bigford8486's Avatar
bigford8486
thats the tpye of spring u have. so if u have to order a new one or an add a leaf thats the code you use.
Old Sep 11, 2006 | 04:35 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
I would, but Ford took all the info out of the Ford parts catalogs, because we were doing swaps and changing out springs and I think someone sued Ford so now they only list the spring code but no load ratings. by the vin number the sales dept could tell you. but finding a salesman to work (whoops) help is a little tough to find.
Ed
but send me your vin number and I'll see what I can do.
Old Sep 12, 2006 | 08:45 AM
burgf250's Avatar
burgf250
Thanks discountfordpart:
My VIN # 1FTNW20S54ED20120
I appreciate the help.
Rick
Old Sep 12, 2006 | 09:39 AM
Parts Guy Wyatt
Former Vendor
Rick
<TABLE width="100%" bgColor=#dddddd border=0><TBODY><TR bgColor=#dddddd><TD colSpan=2>AXLE - REAR AXLE ASSEMBLY </TD><TR bgColor=#ffffdd><TD>EJAGL </TD><TD>6084 LB REAR AXLE ASY </TD></TR></TBODY></TABLE>
<TABLE width="100%" bgColor=#dddddd border=0><TBODY><TR bgColor=#dddddd><TD colSpan=2>AXLE - FINAL DRIVE RATIO - SINGLE SPEED </TD><TR bgColor=#ffffdd><TD>EGAJB </TD><TD>3.73 FINAL DRIVE RATIO </TD></TR></TBODY></TABLE>
<TABLE width="100%" bgColor=#dddddd border=0><TBODY><TR bgColor=#dddddd><TD colSpan=2>AXLE DIFFERENTIAL - REAR </TD><TR bgColor=#ffffdd><TD>EGJAC </TD><TD>LIMITED SLIP REAR AXLE </TD></TR></TBODY></TABLE>
<TABLE width="100%" bgColor=#dddddd border=0><TBODY><TR bgColor=#dddddd><TD colSpan=2>PAYLOAD PACKAGES </TD><TR bgColor=#ffffdd><TD>AA3BE </TD><TD>BASE PAYLOAD PK </TD></TR></TBODY></TABLE>
<TABLE width="100%" bgColor=#dddddd border=0><TBODY><TR bgColor=#dddddd><TD colSpan=2>SPRING - COIL LEFT FRONT </TD><TR bgColor=#ffffdd><TD>TAAKA </TD><TD>F81A 5310 HA L/F COIL </TD><TD><INPUT id=chk248 onclick='javascriptpener.parent.fraTop.buildfeat ("TAAKA","F81A 5310 HA L/F COIL ",checked)' type=checkbox name=chk248></TD></TR><TR bgColor=#dddddd><TD colSpan=2>SPRING - COIL RIGHT FRONT </TD><TR bgColor=#ffffdd><TD>TACKA </TD><TD>F81A 5310 HA R/F COIL </TD><TD><INPUT id=chk250 onclick='javascriptpener.parent.fraTop.buildfeat ("TACKA","F81A 5310 HA R/F COIL ",checked)' type=checkbox name=chk250></TD></TR><TR bgColor=#dddddd><TD colSpan=2>SPRINGS - REAR </TD><TR bgColor=#ffffdd><TD>DZAAB </TD><TD>STD DUTY REAR LEAF SPRINGS </TD></TR></TBODY></TABLE>
IN MATCHING: FILTER ON
CAB STYLE: Crew Cab
SERIES: Ford 250 Series
ENGINE: 6.8L SOHC EFI NA V10 Gas
TRANSMISSION: E4OD(4R100)
DRIVE: LHD RWD
AXLE RATIO: 3.73
AIR CONDITIONING: Manual Air Conditioning
TERRITORY: (+)"USA"
PAINT: Dark Toreador
INTERIOR COLOR: Medium Flint Interior
BUILD DATE: 4/14/2004
VIN DECODE:
MAKE: FORD
TYPE: TRUCK COMPLETED VEHICLE
SERIES: CREW CAB-2WD
ENGINE: 6.8L SEFI SOHC V-10
ASSEM PLANT: JEFFERSON COUNTY, KENTUCKY
RESTRAINT: HYD/CLASS G 8,501-9,000 LBS.
<TABLE><TBODY><TR align=middle><TD colSpan=2>SUSPENSION</TD><TR><TR align=middle><TD>SUSPENSION SPRING CODE: </TD><TD></TD></TR><TR align=middle><TD>SUSPENSION SPRING ID FRONT: </TD><TD>3C345310HA </TD></TR><TR align=middle><TD>SUSPENSION SPRING ID REAR: </TD><TD>4C345560MA</TD></TR></TBODY></TABLE>
Spring code H - SPRING - FRONT
Spring code P - spring - rear Wide Frame (Pickup)
less auxillary spring leaf "FROM 11/23/03"
Just as I thought this is what I can come up with, it might help you. I know it's not exactly what you wanted. but this is all I could come up with.
Ed
