intake questions
Old Sep 10, 2006 | 09:13 PM
camstack's Avatar
camstack
intake questions
I want to put a perfomance intake on my 94 F-150 (5.0). Someone told my I need to put a diferent throtle body on it to truly benefit fom this. Is this true? Also, the NPD catalog shows two diferent kits one w/mass air and one w/o mass air can anyone explain the diference between the two. Id like to get as much hp as possible from this so I want to do it right.
Old Sep 10, 2006 | 09:42 PM
biggreentank's Avatar
biggreentank
The 5.0 supposedly has too large of an intake stock so I don't really know if you'd benefit from this. It would probably be better to get shorty headers and a 2 1/2 inch exhaust system. I'm not sure what year first got mass air but if you have it you'll have a sensor right after the air filter box on the way to the trottle body. If you don't have that then you have speed density.
Old Sep 11, 2006 | 08:20 AM
Conanski's Avatar
Conanski
Yes.. The intake is the last thing that needs replacing on a stock 5.0 truck motor... just for comparison it has substantially more volume than the 5.0 car intake or the 5.8 truck intake. The exhaust system is the place to start on the F150's, specifically with longtube headers and new Y pipe and cat on the 5.0.
Old Sep 11, 2006 | 03:02 PM
camstack's Avatar
camstack
Oh Im good on exaust, I got long tube headers and 2 1/2 inch dual exaust pipes. So is the intake thing worth doing for me???
Old Sep 11, 2006 | 03:41 PM
Conanski's Avatar
Conanski
I personally don't think the intake is worth changing at all. For the money you can get a lot more bang for your $$. Upgrade your cam to a mustang 5.0 roller, and then get a set of GT-40P heads or the AFR's everybody seems to like 'round here.
Old Oct 7, 2006 | 09:28 PM
jhollie's Avatar
jhollie
what will the stock intake on a 95 pull up to in rpms? I have a 331 bottom end with dart heads i'm about to install. Will the stock intake go to 6000 rpm? I've ordered a setup to extend the rpm's on my trans.
Thanks, Jimmie
Old Oct 7, 2006 | 09:33 PM
biggreentank
I think the stock intake would be fine. An Edelbrock or other aftermarket might be a better choice but I'm not sure.
Old Oct 7, 2006 | 10:07 PM
jhollie's Avatar
jhollie
edelbrock goes to 5500 what does the stock goes to?
Old Oct 7, 2006 | 10:18 PM
biggreentank
Well the stock engine isn't going to make much power over 5000 RPM so I'd say it's good to close to that and more since the intake is actually too big for the engine.
Old Oct 8, 2006 | 12:22 AM
jhollie's Avatar
jhollie
check this out!! working on it. https://www.ford-trucks.com/user_gal...130638&width=0
Old Oct 8, 2006 | 01:05 AM
biggreentank
Only cool if that ram air hood is functional
Old Oct 8, 2006 | 01:45 AM
jhollie's Avatar
jhollie
functional hood will not work with the setup I have going! Sold that hood to my dad and now have a 3 inch cowl. I will post new pics tommorow. The truck will hopefully make 450 horses with new setup.
Old Oct 8, 2006 | 01:54 AM
Blurry94's Avatar
Blurry94
Originally Posted by Conanski
Yes.. The intake is the last thing that needs replacing on a stock 5.0 truck motor... just for comparison it has substantially more volume than the 5.0 car intake or the 5.8 truck intake...
Do you have flow number comparisons and/or dyno charts to support this? I'm not saying your wrong, but I'd like to what you have to support your claim.
Old Oct 14, 2006 | 06:31 PM
ranger6202's Avatar
ranger6202
The only thing i've been told by Ford when it comes to upgrading your performance and first things first with your intake...is the MAF sensor upgrade.
Old Oct 15, 2006 | 07:37 PM
Popa Tim's Avatar
Popa Tim
someone makes headers for these heads in a truck????
...not to my knowledge but I'd love to be wrong!
