My 3rd brake light blows
Old Sep 10, 2006 | 08:33 PM
biggreentank's Avatar
biggreentank
What would cause my 3rd brake light bulb to keep blowing out? I'll replace the bulb and it will last for about a month or two.
Old Sep 10, 2006 | 09:45 PM
mgraveman's Avatar
mgraveman
Do you drive with two feet? Could water be getting to it?
That's all I got...
Old Sep 10, 2006 | 09:47 PM
biggreentank
haha. No, no 2 footed driving here. Water could be getting in there I guess but the rubber seems to be in good shape. Could a bad socket cause this?
Old Sep 11, 2006 | 05:49 AM
frederic's Avatar
frederic
It's very likely water got in there, or the socket loosened from the housing and the wires are rubbing on the punched hole in the top of the cab, which rubbed through the insulation.
Old Sep 11, 2006 | 06:39 AM
dave2's Avatar
dave2
Vibration????? Can you mount it on rubber and use a ground wire?
Old Sep 11, 2006 | 08:52 AM
frederic's Avatar
frederic
It is mounted on rubber - the rubber gasket that surrounds the perimeter of the light. Some trucks (depending on vintage) use the screws that hold the light on the cab as the ground, others have a seperate ground wire to the socket with the main power which runs through the headliner to the overhead lights.
Because the gasket sits in the sun all day, eventually it does leak. It's not a matter of if it will leak, but when.
