Bronco II Ford Bronco II
A4LD Question
Old Sep 10, 2006 | 08:17 PM
fl1a's Avatar
fl1a
A4LD Question
I have a 1988 BII with 2wd and auto transmission. I had the transmission
rebuilt by a well recomended shop. My question concerns the shifting points
from 1-2 and 2-3. The transmission when cold, shifts from 1-2 between
3500 and 4000 rpm, and goes to 3rd at 3000 rpm. This is a higher speed
than it would shift before the rebuild. When warm the 1-2 shift ocours at
3000 rpm, and 2-3 at 3000 also. Has anyone else noticed this after a
rebuild? All other functions of the transmission are normal, but the excessive
revs are worrisome. I'd appreciate any comments.
Old Sep 11, 2006 | 10:45 AM
mrshorty's Avatar
mrshorty
In doing the rebuild, did they replace the vacuum modulator? Some replacement vacuum modulators are adjustable. If they replaced the modulator, is the replacement adjustable? If the replacement is adjustable, how did they go about the adjustment?
Old Sep 11, 2006 | 02:03 PM
fl1a's Avatar
fl1a
I don't know for sure if they did replace the vacuum modulator. This is the first
time I have had a transmission rebuilt, and if I need to take it back to them, I
wanted to get an idea if it would be a correctable problem, or something that will
go away with breaking in. It seems to be operating correctly in all other ways.
I'll give it another day or two, it seems to be doing a little better today.
Old Sep 11, 2006 | 05:59 PM
BCTom's Avatar
BCTom
Angry
My knowledge of the A4LD consists of a line item in my cheque book!
The behaviour of your trans sounds similar to the performance of mine after I had it rebuilt. Seems like it holds the revs longer to warm up quicker or somethiong. There are quite a few mods made by a good transmission shop to these transmissions when they are rebuilt so it's no surprise that it will act a little differently. Mine still leaks around the vacuum modulator a small amount even after the rebuild, despite everyones best efforts. I just put up with it. However I can tell when the ATF is even the slightest bit low, even 50 or 60 millilitres. The shifts are sloppy and the converter doesn't seem to lock up quite as quickly.
Good luck!
Old Sep 11, 2006 | 09:44 PM
fl1a's Avatar
fl1a
I agree, that transmission bill dried up my rainy day money. I've not seen any
leaks yet, but if I do, it will be time to test the warranty.
IFaMiNe92
13
Jan 23, 2017 02:07 PM
deputydog03
Mar 16, 2016 09:42 AM
Studio48
2004 - 2008 F150
Jul 27, 2013 07:22 AM
springer9861
Mar 16, 2004 10:47 AM
XLRanger
Mar 27, 2002 09:28 PM
