Sponsored by: Real Truck
Checking The Mil
Old Sep 10, 2006 | 04:50 PM
03SUPERDUTYF350's Avatar
03SUPERDUTYF350
Checking The Mil
I went to auto zone to get the mil checked and they plugged it in and there was no power coming from the plug it wouldnt register in there computer.. so i went and rented one from checker and the same ****.. is there a fuse for this or something that i can check it looks like all the wires are fine..
oh yeah its a 2003 f-350 6.0l
Old Sep 10, 2006 | 06:11 PM
rwilimo's Avatar
rwilimo
Check the fuses. It might be 1 of the cig. lighter fuses.
Old Sep 11, 2006 | 10:37 AM
03SUPERDUTYF350
if my tow haul light is flashing i should be able to pull a code with a standard code reader at the same plug correct? or is there a special transmission plug? to get the codes from???? my tow haul light only flashes when drivin warm then it wil shut off when i shut the truck off and turn it on again but my transmission is shifting hard..
Old Sep 12, 2006 | 10:52 AM
03SUPERDUTYF350
i pulled the pan off and check the torque on the valve body seems good is there a way to check all the solnoids???? is there a how to artical on replacing the epc???? any help would be great..
Old Sep 12, 2006 | 02:34 PM
biz4two's Avatar
biz4two
Arrow
All codes (engine or tranny) are stored in the PCM. The only fuse(s) for the OBD II port or PCM that I could find are the following...
Fuse #12 is a 20A mini yellow fuse for Cigar lighter / OBD II
Fuse #36 is a 10A mini red fuse for the PCM memory
Good luck...
biz
