Rough idle andrough running
Old Sep 10, 2006 | 02:28 PM
eviltrekker's Avatar
eviltrekker
i have a 96 f-350 that runs rough down the road. i have to have it floored to get to 45 mph,this is fast i can go. i replaced the wiring under the driver side vc,and helped for about 10 minutes then the same thing.the i plug that plugs into vc gasket is melted on the glow plug pin.it is hard starting,the rpm gauge goes to 100 when starting. when running in idle it is vey rough and making a sound like rapping ,like a rod going. any ideas. did not change passenger side vc gasket or wiring. i am lost on this problem. i like my truck
Old Sep 10, 2006 | 04:24 PM
1997F-350's Avatar
1997F-350
pull both vc's and see what you got. unless you know someone who can buzz test ya.
once you got em pulled look for burnt stuff and then start it and watch the oil spouts for oil.
Old Sep 10, 2006 | 04:51 PM
eviltrekker
thank you
i will try that monday. i will let you know
Old Sep 13, 2006 | 03:58 PM
eviltrekker
i dont know what is going on it will run fine then start running and idling rough. bad desiel or possibly electrical. any suggestions
