low idle.??
Old Sep 9, 2006 | 04:23 PM
johnzie's Avatar
johnzie
low idle.??
Hi Guys....A friend of mine here in the UK has a problem with his F350..I'll give as much info as i know...hope it helps...
95 F350 dually...powerstroke turbo v8 diesel...( electronic injectors.?)..fly by wire....ie:- no throttle cable......
He seems to think the idle is low, sometimes it will cut out when coming to a stop...more so with the air con on....he can't seem to find an idle screw/adjuster...Any help would be appreciated...( rev counter says approx 600rpm on idle)
Thanks.... Chris...
Old Sep 9, 2006 | 04:39 PM
Cuda_jim's Avatar
Cuda_jim
Automatic or standard tranny?
IS the check engine light on?
Check oil levl and quality (due for an oil/filt change).
Same for the tranny if it's an auto.
Is it getting enough fuel ie, fuel pressure check, replace filter.
Old Sep 9, 2006 | 05:06 PM
1997F-350's Avatar
1997F-350
cant adjust the idle with a screwdrier on these trucks its all electronic.
the idle speed sounds just about right to me. i think the autos idle at like 650 and manuals 600.
does he have access to a code reader?
sounds like it is losing hpo pressure or fuel pressure making it die.
Old Sep 10, 2006 | 04:52 PM
johnzie's Avatar
johnzie
re:- low idle
Thanks for the replys...have passed info on to friend....no codes showing...dosn't have access to a reader :-) he's about to do a full service in the next week or so....eng/tranny (auto)/fuel filter etc...
Thing is...it dosn't do it all the time...mainly on start-up (sometimes). more-so when the air con is on...thats what got us thinking about the idle....
Anyways...thanks again.....will keep posted... Chris..
