Wrong Fuel Filter? (2000 3.0 FFV)
Old Sep 8, 2006 | 08:39 PM
lumberranger's Avatar
lumberranger
Decided I'd change my fuel filter on my new (used) 2000 Ranger 3.0 FFV 4x4.
Checked underneath so I'd know what I was getting into, and found what was clearly an aftermarket filter that was plastic, and had three connections (two input lines, and one output line). It was not properly secured, it had a 5/16" bolt molded into the body that should have secured it to the chassis frame.
Went to the nearby Checker Auto Parts, and found all the fuel filters carried for my engine only had two connections, one input and one output!
However, all the filters listed for the non-FFV 3.0 engine had three connections. I saw no alternative (couldn't exactly leave a fuel line hanging!) so I got one of these non-FFV filters. It fit fine.
Has anyone experienced this? I definitely have a "VIN V" engine and all indications of a FFV engine (including the sticker on the gas door). I've read other posts that indicate the correct fuel filter is hard to find for the FFVs (Fram doesn't even list one), but the "correct" one won't fit!
Old Sep 8, 2006 | 10:22 PM
eigenvector's Avatar
eigenvector
Yeah I had the exact same experience. I think there is some confusion among the parts people as to what is and what isn't a FFV truck.
The filter should be a 3 connection type, one input, one evaporator line, and one line to the engine. The brake line should fit into the metal bracket that comes with it, and the bolt goes on the frame. I had problems getting the brake line to come out of that bracket - didn't want to bend or kink it. I also had problems getting the fuel lines off, but that was more out of fear of getting a face full of fuel rather than snapping the lines. Why they chose to put the fuel filter in such an inconvenient place I'll never know.
Old Sep 10, 2006 | 10:25 AM
lumberranger
Is that the fuel pump?
Thanks for the reply, eigenvector. Glad I'm not the only one. Just out of curiousity, I noticed the fuel line went into a device just downstream of the filter. Is that the fuel pump? I had assumed the pump was probably on the fuel tank, but this thing looks easy to get to...
Old Sep 10, 2006 | 12:58 PM
eigenvector
Fuel pump is in the tank, I don't know what is downstream
boulderdentist
Electrical Systems/Wiring
Oct 6, 2017 10:08 AM
silverfrost99
2004 - 2008 F150
13
Jun 13, 2007 08:51 AM
TOUGHLover
Apr 13, 2007 10:22 PM
snowbound1234
Apr 11, 2004 04:09 PM
