Sponsored by: Real Truck
Reverse Light Wiring
Old Sep 8, 2006 | 07:45 PM
deker9's Avatar
deker9
Does anyone know if there is pre-installed wiring running to the back of the 2006 F250 CC Long Box that I can use to run a set of lights back there?
Old Sep 8, 2006 | 10:13 PM
Bear Hunter's Avatar
Bear Hunter
Tap into the reverse wire behind your tailight and use it to trigger a relay.
Here is a wiring schematic....it includes wiring in a switch using a diode. This setup allows the lights to come on when the truck is in reverse and allows you to flip a switch and turn them on at anytime:
Old Sep 9, 2006 | 02:06 PM
oldkountryboy's Avatar
oldkountryboy
bear has you covered that is basically the same way i have mine set up
works like a charm makes backing up a lot easier
Old Sep 9, 2006 | 02:12 PM
MO2002F250's Avatar
MO2002F250
I have been toyin with this for my 02 250. What is the diod for? and what size diod do you use? I was going to tap into the purple wire for my 7 pin hitch for power when in Reverse and run a two position relay.
